hi, i need that AOP in my library. It contains 3 units and is always shown like this, for exemple unit A::
So i created the symbol in the editor, i used the TL072 symbol, with the mirror tool i placed correctly the legs 2 and 3, so far so good:
Same for unit B.
Then when i want to use AN6562 in a schematic at first everything is fine.But when i do the automatic component numbering, the wire of AN6562 are broken, i don’t understand why:
Is there any other device in the symbol lib with exactly the same pinout?
If yes, open that symbol and add the ANxxx as an Alias. There is a tab for that in the symbol editor.
I have kind of a dumb idea. I wonder whether you were consistent with your grid size? Did you possibly edit the symbol using a 25 mil grid so that it could not be properly placed in Eeschema using 50 mil grid? If I am correct, you can probably go into symbol editor and move everything up one 25 mil grid, then save the symbol.
BTW Digikey, Mouser, and I do not recognize the number “AN6562” and I wonder whether that is a designation for an application note rather than an op amp IC?
I’ve searched for one, out of the ten i looked at none of them corresponded, in equivalent there is LM358 which is not in the library.
AN 6562 datasheet:
No, mirroring in the schematic keeps the functionality correct. After all, pins can be arranged and positioned arbitrarily anyways. The user must of course change the wires manually if the symbol is mirrored and was wired already.
Why did you change anything on the graphic part in the library at all?
Pin-out of your opamp is the same as from any old regular opamp, so you can just put a TL072 on your schematic and then change the “value” field to AN1358. It’s just a string of text.
There is only a need to differentiate when you want the links to the datasheets to work, or start attaching Spice models and such.
