I am learning KiCAD from one month and i am facing problem during placing mechanical symbol and via array. Anybody knows how to place mechanical symbol and via array in Board area?
I am not sure if people know what you actually want to know so please write a little bit more about what you mean with “mechanical symbol”.
The Via array can be solved with this little trick: Protip: nicer via stitching
Thank you.
The link is useful.
Mechanical symbol means unplated holes. I have to put it at edge of board corner.
Create a new footprint and select NPTH for pad type once you placed one.
Set up diameter/etc how you want. Shape & Drill should be circular
