I have a hierarchical project with many sheets and want to put all of them in a folder.
I can do that for all .sch except by the main/initial schematic.
Is there any config to do that? I couldn’t find anything in the .pro file.
I think root schematic sheet has to be in same folder as project file.
Workaround is to have root schematic as a simple empty placeholder for the actual “root” sheet that will be hierarchical. You can place the fake root anywhere you want.
So it is always required to have one .sch on the root with or without the workaround. So it makes no difference to use the workaround, for me. Thank you @qu1ck
