In KiCAD PCB editor, if you right click a footprint and select “open in footprint editor”, it brings up the footprint as saved within your layout. Is there a faster way to open the actual library footprint than opening up footprint editor and navigating through the library tree to the footprint you want to edit? Like a context-sensitive “edit in library” command? Thanks!
