I have routed a PCB along with a connector. Now when I move the connector the tracks dont move. There is a rats nest which appears. How do I select the tracks along with a connector?
Same as in eeschema… [G] instead of [M].
I just don’t know if the mor recent version(s) of KiCAD are able to keep tracks aligned (horizontal/vertical/45deg) when one does that… same problem in eeschema I think.
So the layout will become distorted most of the time you do that - others might have a trick up their sleeve I don’t know yet .
