I am wondering how we can find the distance between two points in KiCad layout and also how can find the placement coordinate of a component in Kicad layout.
There is a Measure Tool in KiCad PCB Editor. You can find this on the tool panel on the right or from the Inspect menu.
assuming “component” == footprint:
- doubleclick footprint → get footprint properties dialog → bottom left edge: area with value for position+orientation
- or: enable properties panel (View–>panels–>properties), select any single footprint → get position values in section “basic properties”
- or: File–>Fabrication output–>component placement–>position file. Then memorize the reference designator from your footprint and look into the position file for x/y position
