I added rounded corners to my board using the arc tool in the edge cuts layer. It looked ok but in the Gerber viewer I discovered that I had punched a circular hole near the corner. Must have been one of my failed attempts to draw an arc. I went back to the layout but I couldn’t see a circle to delete no matter how much I zoomed in or what other layers I turned off. Eventually I resorted to deleting the whole edge cuts layer and redoing the edges which didn’t take that long.
So was there something I should have done to find that circle in the edge cuts layer? Sorry, I didn’t make a snapshot of the evidence.
The bug you reference is with regards to kicad not allowing traces to be drawin within an arc. It has been fixed with version 5.1.4. See https://bugs.launchpad.net/kicad/+bug/1826014
Unfortunatly the arcs need to fit quite perfectly to the lines forming the contour, otherwise there are problems. 3D Viewer will complain of unclosed countour and normally will tell you where the problem is. Maybe this is what you experienced.
