I use a lot of hierarchical sheets in my PCB designs, and I’d like to associate a default PCB layout with those sheets. pcbnew already groups components together that belong to the same hierarchical sheet, but I’d like a way to have intra-sheet traces, etc. already laid out as well, effectively making multiple “modules” that are easier/better/proven to layout on the board. Is there a good way to do this? Sarkari Result Pnr Status
Currently there is no good way to do this.
I am considering making an action plugin to support his workflow, but it will not be available before summer.
If you open Pcbnew in “standalone” mode you can open and add PCB’s from different projects into one file. This is sometimes used as a hack to make panels with different PCB’s, but can also be used to import the components / tracks / board outline of a pcb as a “module”.
Pcbnew is opened in standalone mode if you start it directly from a command line window or from your operating system’s menu. (That is, not from the KiCad project manager).
It turns out it was way easier to do than I thought initially. Once it clicked that this is basically just replicate layout but across different files it was quite easy though. Anyhow you might want to take a look at Save/Restore layout action plugin.
