Another Eagle user question - how to separate a power pins to make a layout more readable? So basically, I want to move outside a power pins from an LM741 footprint.
Thanks J
Thanks J
Do you actually mean schematic and symbol, rather than layout and footprint? Layouts are usually not intended to be readable, and you can’t move the pins from their positions because they are part of the package.
Yes, I mean the schematic symbol - V+ and V-. Normally, I can do this in Eagle just using the “invoke” command, than it shows all of the parts of the package I can use (eg. PWR pins).
J
You’d have to edit a copy of the symbol to change the positions of the pins.
In KiCad the LM741 has all pins defined in a single unit:
And so do the other single opamps.
It’s only with dual and more opamps that the power pins get separated in a separate unit. With the TL072 for example (see below) Units A and B are the regular triangular opamp symbols, while unit C are the power pins. This unit is designed to fit on top of one of the opamps, so you can use it either with similar looks as a single opamp, or collect them with other power symbol units in some power supply section.
To have the power-pins on a different position or on a different unit you have follow retiredfeline: copy the symbol to your own library and modify it. As example for a multi-unit-symbol with dedicated power-unit look at LTC1519. You could use that as starting point for your own multi-unit symbol.
Also please use the correct description - symbols are used in the schematic, footprints are used in the board-editor. Mixing these terms could make it difficult to understand you.
Kicad has no invoke-command. If you want to “invoke” (==get more units from a symbol onto the schematic) a symbol:
Thanks a lot for the clear explanation. I have already check some options and have solved the problem. I love KK more, and more. I’m long time Eagle user and boy… believe me some things are simpler and more straightforward with KK. Just finishing my first design in KK and it was flawless. Key commands are amazing. I will dive into my own footprints soon. during the years with Eagle I made some nice and big library of my own devices and footprints, I would love to import them if it’s a simple way to do it (?). And sorry for an incorrect description. J
