I have Pop!_OS 21.04, which is based on Ubuntu. I need to start using the nightly builds because there are library entries I need that are built for KiCad 6. Pop!_Shop (the Pop!_OS software manager) currently installs KiCad 5.12.
I followed the instructions on page:
The ppa is installed. But missing in these instructions is how to install the KiCad nightly build. I guessed, and tried the command: sudo apt install kicad
This installed version 5.1.9. What is the command that will install KiCad from the nightly build ppa?
A PPA supplies any number of packages. There may be a command in your package manager (I don’t know Pop!OS or Ubuntu well) to show you what packages matching a word or pattern are available to install and the version.
If the PPA is set up correctly, the package manager should let you know when updates are available. I assume it will let you know when the real release is available to supercede the nightly. But I don’t know the details.
