How to increase Copper size in Pads
I will use MountingHole_Pads to connect a MosFet to an external wire via an inox screw.
The system automatically places four small traces of copper connecting the copper plate to the pad itself.
I have read PCB Editor | 6.0 | English | Documentation | KiCad, but I am not able to detect where is it explained.
May I increase the width of the copper traces or put four more ?
Thanks a lot,
Regards,
Horacio
Those are called ā€œthermal reliefsā€, and you can find the settings for them in the properties of the copper zone.
Thanks so much, Paul !
Solved
Thermal reliefs are there to make soldering easier. A solid copper zone can conduct a lot of heat away from your soldering iron (or however you solder) when you solder a through-hole pin. But sometimes you need to conduct heat away from a power semiconductor. Thermal reliefs work against that. I usually do not use thermal reliefs…and yes soldering is more difficult as a result.
