So I brought a SVG into inkscape and used the SVG2shenzhen to save it as a module. The challenge I have is that I cannot figure out how to import this “module” into Kicad. The “module” saving option created a (as seen attached as well):
1- fp-lib-table
2- A folder
i- Image folder with a PNG of the board
ii-.pickle file
iii-.hash files (I only saved the F Cu layer as a test).
I could not use any of the information on the github as every online example and even the examples on the github saved the files as a pcb versus a module. I could not see how to import the .pickle and .hash files into kicad to use.
Any suggestions would be incredible!
