How to ignore clearance for one whole component and its pad in DRC
Hello everyone,
I have a clearance rule: 0.5mm for GND. But there is a component on my design that has 0.2mm pitch and also GND pads.
My question: Is there any way to ignore/exclude clearance errors on a specific component (and its pads)?
I am aware of the one by one right click and exclude/ignore method in Design Rule Checker window; I am asking for a whole component ignorance here.
If so, I can ignore very fast all >100 errors due to small pitch on ICs then I can focus better on the real clearance errors…
Thanks in advance.
Select the pad.
Press ‘E’
Goto Tab ‘Clearance override’ and type in the new clearance.
Thank you for your reply.
The thing is, that is not “the pad”, it’s about 200 smd pads belonging to ICs. I do not see that as an efficient way.
Select all of them and bulk edit the clearance override in the property editor.
