How to get arc tracks
In V5 to have arcs at copper layer I was making arcs at graphic layer and then changed their layer.
Is it possible in V7 to route arc track? If yes - how to get such track?
I have round ferryte and want to design laying at it round RFID antenna. I think of doing it as PCB design and not footprint design.
I remember that trying to do such things as footprint there were problems with vias and tracks at other then top layer.
I plan to have 3 coils each on separate layer of 4 layer PCB and EMI shield at bottom.
Hi, I don’t know the answer to your question.
But as far as I know, when doing a footprint, you cannot add copper to the inner layers. The inner layers are disabled in the footprint editor.
I could be possible to do it by editing the layer of specific part inside the footprint file (manually with a text editor), But I don’t think that it can be done via the footprint editor.
In principle yes.
  1. routing with corner-mode set to: “90 degree rounded”. This places an 90°-arc at every track-bending. To change the corner-mode:
  • hotkey “track corner mode”
  • or during routing: RMB-click–>context-menu–>cycle corner mode
  1. all copper graphics can be converted to tracks and than subsequently can be assigned a netname:
  • draw a arc/circle on the wanted layer
  • this graphic element has the old problem of creating a DRC-error with all other standard tracks
  • select the graphic–>RMB–>context menu–>Create from selection–>Create Tracks from selection
  • the original graphics remain selected, delete them
  • select the new created tracks–>doubleclick–>assign a netname in the track properties dialog
regarding footprint and copper on inner layers: still not possible
What I remember there were some problems even with track at bottom (part of coil) connected by vias. Because of this I decided to not try to do that antenna as a footprint. I supposed (but not checked it) that using inner layers in footprint is also problematic.
Thanks.
This is probably the right way for me (I need something about 340 .. 350 degree arcs).
Filleted Lines or Circle works similarly but, not identically the same.
I use the Circle approach to get cleaner Arc segment from Circle’s.
Creating a Track from a Circle or Arc creates a ‘Hidden’ Duplicated item.
The example below shows that I set the Line-width (to be able to visually differentiate the two lines) then, I delete the Graphic and Double-Click the ‘Created Track’ and set it’s width and NET (and delete the graphic).
I think it is about this:
I have changed plans and I am doing something else so didn’t checked myself how it works. I have only written in my KiCad cheat sheet the information I got to have it at hand.
