Is there a way to forward user fields from schematic symbols to layout footprints?
Just tried to add ‘manf’ to a footprint, because my symbols have this field, but upon opening cvpcb it complains about thi being an unknown thing and stops loading the library…
So, probably no.
Yes, I suppose it’s only “Reference” and “Value” fields that get forwarded from schematic to layout
What did you had in mind to forward besides those? - really curious
Well, in this particular case I have a symbol with no pins that defines a bare PCB. Once added to schematic it automatically appears in BOM export. This symbol has a user field “Partnumber”. I’d like to assign a footprint to this symbol with the value of symbol’s “Partnumber” field being put on “F.Cu” layer of the footprint.
Sure, I could use the “Value” field for that but I don’t want to break the way my library is organized: where necessary I assign separate user fields to symbols in schematic (e.g. “Manufacturer”, “Partnumber”, “Package”, “Resistance”, “Capacitance”, “Current” etc).
So at the moment my workaround is to have a separate footprint per PCB design revision on which I add bare PCB partnumber in simple text on “F.Cu” layer (with help of text editor
Yeah, must be something that is hard coded for Value and Reference fields… just tried with a ‘user’ field in the symbols definition (as other text in the footprint has this field name), but nothing comes through.
The pcb partnumber field then ‘describes’ the finished/populated pcb or is it the ordering number at the board house?
Thanks for sharing the workflow though.
PCB partnumber is for bare PCB. It’s something I assign myself and use as ordering number at board manufacturer.
Here is a more detailed description of my system:
Bare PCB naming convention: {design name}-PCB-{ver}, where:
{ver} - layout version
Example: PCIERISER-PCB-0: PCIERISER bare board, layout version “0”
PCBs with different layout version differ in some features of bare PCBs
Create schematic symbol to denote bare board. It shall appear in BOM and as copper or silkscreen text in layout
Assembled PCA naming convention: {design name}-PCA-{ver}-{var}, where:
{var} - assembly variant (related to the layout version)
Example: PCIERISER-PCA-0-0: PCIERISER assembled board, layout version “0”, assembly variant “0”
Each layout version has its own assembly variants numbering starting from “0”
Create schematic symbol to denote board assembly variant. It shall appear in BOM and as a placeholder for a label in layout
Build batch naming convention: {design name}-BLD-{date}, where:
{date} - build date
Example: PCIERISER-BLD-20151201: PCIERISER assembled board, build on 1st December 2015
Create schematic symbol to denote assembly build. It shall appear in BOM and as a placeholder for a label in layout
