How to draw straight tracks between 2 points
Is there a way in KiCAD 8 to draw a straight track between two points?
For some reason, I cannot turn off the H/V/45 degree constraint. I know the “shift space” function (and the corresponding knob in the left menu), but it does not change anything. When I turn off the constraint, the “constraint” indicator in the lower status bar is tuned off, but the behavior, when drawing tracks, is unchanged und still constraint to H, V, 45 degree.
KiCAD can easily deal with straight lines between two points. It is possible to edit the properties of tracks, which has the effect I want. But I would like to have a graphical way, by simply clicking on the start and end-point.
Any help would be appreciated.
Works fine with me. Perhaps you need to upgrade to 8.0.8?
Right-click on this icon:
Enable “Free angle mode”:
@das-t, you made my day! Thank you very much.
But tell me: why is this under “highlight collisions”. This has nothing to do with collisions, doesn’t it?
Because Shove and Walkaround is not supported in Free angle mode, it can only Highlight collisions.
got it, dsa-t. thank you!
Didn’t tried it and didn’t searched it but ‘by the way’ would like to know.
Do rounded corner tracks existing at PCB will be tolerated by Shove mode?
First I thought this should be said vice versa, “Free angle mode is not supported under Shove or Walkaround”, then I noticed it would be redundant and self-evident from the dialog, then I noticed it’s like that no matter how we formulate it, and we still don’t have an explanation. :laughing:
I would say that drawing freely (using free angles) is not compatible with the idea of Shove or Walkaround. Those two are closely related and use automatic manipulation of track segments. It wouldn’t make sense to force them to keep some oddly angled tracks while trying to otherwise find the best route efficiently.
We’d probably need to implement (or integrate) something like TopoR for that.
It’s even possible to use TopoR through Specctra DSN/SES files already.
