How to draw inside structure of a component?
I’m quite sure the answer to my question is evident, but I was not able to find it: I’d like to draw the internal structure of a component, similarly to this one. I found how to draw lines, but I’m still unable to draw small arrows…
How can I do this?
Pascal.
either [E] key while hovering with mouse cursor over one of the lines that enclose a space or [RMB] (right mouse button) onto the line and then ‘Edit Line Options’.
See the ‘Fill Style’ options?
Joan,
Thanks for your answer. Yes, I have already discovered the commands you describe. I was able to modify an existing component, generating this drawing: I was able to remove the small slanted triangle used to depict the emitter of the top phototransistor. And I drew another triangle (the huge one :slight_smile:) but was unable to decrease its size and to make it slanted.
[RMB] and ‘Grid Select’… go as fine as you can manage… zoom is restricted in EEschema/symbold editor though, so the very fine values are ‘useless’.
Also it’s imperial, just roll with it… won’t change in the near future, but in the far future afaik.
Thanks a lot, got it!
