I would like to do terminal block 3D models. But the blocks I will use have 4…10 pins.
My idea is to make a model of everything around one screw and then multiply it as many times as needed by using Draft WB Array.
I move in FC like a blind man.
I have tried to make these one screw part using Part WB because my previous experiences tell me that in Part WB I have less color problems then in Part Design WB. But even so my model lost colors at some walls even when using StepUp Simple Copy objects (and even doing before the Make Union or Make Compound).
Today I discovered that Part can have several Bodies
So my idea is to use separate body for plastic, and separate for metal.
I have done simple Part containing two bodies (each with different color). Using StepUp Simple Copy I am able to get 3D models (I have tried it only for 2 screws but suppose it will work). But it would be simpler if I could use an Array.
So using Draft Array I created a row of my Parts. Colors are preserved. And now I have a problem to export it as 3D model. Using StepUp “Export 3D model” on my Array I get a series of errors (yesterday I got the last FC 0.19 I found and the current StepUp).
So according to my previous experiences I tried to first run at that Array the KSU “Make a Union” but I got “Select a Compound or a Part Design group or more then one Part object!” eroor. The same error I get when trying to run KSU “Make a Compound…”.
I have also tried to run KSU “Make a Union…” on my Part before doing the array.
Do anyone can tell me what are the new elements I get after “Make a Union…” I run it at my Part and I get Part_fd and Part_sp. I think there is no help function in FC explaining what is what. Under right-click I see no position suggesting that I will be able to get some info about this element.
I have done array from Part_sp and next time from Part_fp and in both cases I get to the same problem with exporting what I have to 3D model.
I have also done the same tries replacing “Make a Union…” with “Make a Compound…” with the same result.
So I am in such state that I can get in 3D window what I need but I can’t export it as a 3D model (I have tested it only at this simple model (each of my bodies have one Pad from one simple Sketch (a circle)).
I am not citing the errors as I suppose it is simple and fast to reproduce it, and may be during it some more experienced in it can just get the idea what I am doing wrong.
So 2 subjects:
- What are the _fd and _sp ?
- How to get 3D model from Array ?
