I am new to Kicad and I was wondering how to do fixing holes ?
Do I have to create a new footprint with just a mechanical hole ? If yes, how can I relate it to my GND so that I have a common GND ?
Moreover, I would like to know if it is possible on pcbnew to place components at specific coordinates automatically ?
You will need to do it as you already guessed. Create a footprint with one pad.
There are two ways to connect it with ground.
option 1: make a one pin symbol and connect it in eeschem with gnd.
option 2: edit the pin options of the footprint in pcb_new and connect it there.
Work flow of option 2: https://contextualelectronics.com/learning/via-stitching-in-kicad/
2.) Auto placement of parts (holes)
I don’t know of any automatic placement capabilities build in within kicad.
You could write a python script
You could use dxf import and place your mounting holes as close as possible.
for that you could look at this post:
