Hi all.
I’ve recently split a project into two boards after having done a bunch of the layout.
I duplicated the project and put the two projects into separate folders, then deleted the unneeded parts from each project. That worked great.
My issue now is that one of my projects has a top level sheet with nothing on it but the reference to the second sheet. I’ve tried a bunch of things, but can’t seem to delete the top level sheet or promote the second sheet without forcing a complete reannotation and resetting the layout of the components from the lower level sheets.
Is there a way to delete the top level sheet or promote the bottom sheet that preserves the annotations and layout?
Thanks in advance, I’m pulling out my hair on this one…
