I wanted to delete the pin name for several selected pins:
But when I click into the property field it already is empty:
There I can only enter a number which will be then common to all selected pins or if I only hit Enter, the values stay like they are.
Is there a way to perform this operation or is it just missing?
Regards,
Hannes
2 ideas:
- maybe the Edit–>Pin Table dialog helps you
- if you want to use the properties panel:
- set all selected pins to the same pinname (commit with ENTER)
- and with a second step you are able to clear the pinname parameter to a empty value
sidenote: please mention always the used kicad version in your question. This helps to give correct answers without many callback questions.
Ah great, the second suggestion is what works best for me.
system
Closed
4
