I am wondering about what are the ‘best practices’ to produce a slot as part of a footprint.
For a particular connector, there is a slot used for a ‘snap-in’ plastic part of the connector which assists in retaining/ supporting the connector.
This does not need to be electrically connected.
The particular slot is 3.2mm long by 2.2mm wide.
Looking at previous postings, there appears to be two possible approaches:
- Add a ‘NPTH, Mechanical’ ‘oval’ ‘pad’ in the footprint editor.
In addition to defining the hole shape oval X and Y size, is it necessary to also define the ‘pad shape’ as being oval and of the same dimensions as the oval hole?
If I understand correctly, if the ‘Pad size X’ and ‘Pad size Y’ values were set to zero (or less than the hole dimensions), it would imply/ result in solder mask being place over the hole (i.e., empty space!) - which may make the PCB fabricator unhappy?!
If on the other hand the pad is made somewhat greater than the hole dimensions, it would result in the solder mask being spaced away from the edge of the hole?
Would that be a good practice, bearing in mind manufacturing tolerances for mask placement, etc.?
Refer graphic:
- Define the slot in an ‘Edge cuts’ drawing.
Looking at the JLCPCB capabilities web-page, they state:
Min. Plated Slots
0.5mm
The minimum plated slot width is 0.5mm, which is drawn with a pad.
Min. Non-Plated Slots
1.0mm
The minimum Non-Plated Slot Width is 1.0mm, please draw the slot outline in the mechanical layer (GML or GKO)
If I understand the JLCPCB capabilities correctly, for the current application, I should use approach 2, i.e., define the slot in an ‘Edge cuts’ drawing.
Is the ‘GML or GKO’ layer that JLCPCB refer to the Kicad ‘Edge cuts’ layer?
For other applications, I envisage a need for Plated Slots so am also interested in understanding the best practices for such slots.
