How to copy paste footprint in layout and re-assign components
Hi, I am designing a twin circuit which like 80% of it is same layout but 2 times. Is there a way to layout 1 part, copy paste it and reassign the components identifiers of the second part without changing the net-list ?
Right now you can copy/paste the two sections in the PCB and then manually rename the designators to make them match the schematic. Have a look at this post below:
From the little info I can read here, this seems to be an excellent candidate for the “Replicate Layout” script. (Search this forum (or github) for those magic words).
This workflow worked ! I duplicated the layout, edit reference following schematic, deleted the non-layout-ed footprints and updated the pcb with the options suggested in the link suggested. It worked ! Thanks a lot
