I have some line art I created to show the board stack up in the first board I made in KiCad, its quite extensive and I would like to copy an paste it from the old board to the new board. Is this possible (or can it be done through some kind of export functionality)?
Copy the first board, trim everything except your line art, save the file.
Open PCBNew in standalone mode (invoked directly from your OS shell), open your new project, and use File > Append board command to open your prepared Line art file prepared in earlier step.
That seems like it will work in theory, but after spending 15 minutes on it and not getting it to work I’m starting to feel like it would be easier to redraw the line art.
Anyway, such a trivial (at least from user’s point of view) operation is still quite awkward with current Kicads. This whole “standalone mode” / “project mode” approach is far from being intuitive - as the OP’s question frequents this forum.
Do you know of any major improvements to the whole copy/paste mechanism for the upcoming next big release (v6)?
Even in 5.1 copypaste works between Pcbnew windows. The problem of two modes is a different matter. I don’t know how copypaste could be easier because it already works just like in any software. How else would you copypaste between two different files?
The differences between v5 and v6 are that copypaste works in eeschema, too; and the system clipboard is used so that it’s possible to for example paste a part of a pcb design to a text editor.
ok thats odd…
I recently did exactly what the OP was after (eco1_user contains additional information) and I needed to replicate similar info to the other boards & then edit.
I tried exactly that and it didn’t work, thats why I went the copy-paste of the raw pcb file data
Now I just tried it and it behaves exactly as you stated. Oh well multiple ways as least.
Just checked and thanks, it works for PCBNew, was sure that I can’t close PCBNew window to retain the clipboard.
I’m happy to hear EESCHEMA is getting “civilized” with the new release.
For me the intuitive way would be to export the border and then import it somewhere else, unfortunately there is export in SVG but not import and there is import of DXF but not export, so at the moment not possible.
But there is: Pcbnew / File / Plot / Plot format: DXF
I am experimenting a bit with it now, but it works strangely.
After plotting to dxf as mm instead of inches, I managed to first plot the board to DXF (which creates a file for each layer), and then Pcbnew / File / Import / Import Graphics and I imported the F_CU layer onto the silkscreen.
Result was an outline of all copper tracks, but it does work.
Works for me too with KiCad V5.1.8 and Linux Mint.
I opened 2 PCB’s in 2 standalone instances of Pcbnew, did a copy in one and pasted in the other Pcbnew instance.
Application: Pcbnew
Version: 5.1.8-db9833491~87~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-52-generic x86_64, 64 bit, Little endian, wxGTK
Boost: 1.71.0
Curl: 7.68.0
Compiler: GCC 9.3.0 with C++ ABI 1013
