How to copy and paste line segments when making components??
As far as i know one can only copy a block not a single element.
So the workaround would be to drag a block around the element you want to copy. Than rightclick->copy block. Place the copy where you want it to be placed.
If you want to copy something from one unit to another unit (in a multiunit symbol) Proceed as above but place the copy in the same unit on a place where it is not in your way. Edit its properties such that it appears on all units.
Switch to the unit you want it to be copied to. Edit it such that it appears only on the active unit.
