Hi, I have a bus name created as ContolSignals{SDA SCL RS485_IC_TXD RS485_IC_RXD RS485_IC_TXE RS485_IC_RXE SPARE_UART_TXD SPARE_UART_RXD RS232_TTL_TXD RS232_TTL_RXD etc… } Is there any way to collapse all the list of signals name? as long as I see only “ControlSignals” I am happy.
You should be able to create a bus alias under Tools->Bus Definitions… as shown below
If you configure your bus alias like the below, will allow you to use a label like {ControlSignals}
in your design.
More information in the manual: Schematic Editor | 6.0 | English | Documentation | KiCad Note that the manual is not fully up to date for KiCad 6.0 - some areas are still referring to old 5.x ways of doing things
I missed the curly brackets, that’s why it was not working. Thank you very much!
