How to change track width for one track?
Hello there!
I need route one track with different width. E.g. ground common (0.8 mm) and ground before chippad (0.25 mm).
Add your favorite track widths to the global rules in Design Rules. During route you can use W / Ctrl-W key shortcuts to select track width for current segment (two-segments).
In openGL mode you can enter a custom track width in the context menu (right click while routing), ideal for one-off jobs.
If you run into this more often, I recommend the previously mentioned method.
Yes! I doing it. Thank you all.
