How to change footprint
Hi, I went into my schematic and changed a whole lot of diode footprints to a new footprint I had created and then clicked ‘Update PCB from Schematic’ but the original footprints were not replaced. I went back to the schematic, and the new footprints I had inserted had all reverted back to the original ones.
Any hints at what I am doing wrong appreciated. Cheers.
A
Where did you store the footprint you created?
In my library with all my other footprints.
A
You opened each symbol property and replaced the footprint and pressed OK?
When you updated the PCB, the “Update PCB from Schematic” window had what written message?
Ahh - I found it. I did not click to update footprints in the dialog box.
Problem solved - thanks
