I want to dimension a small dimension (0.6mm) using the tool “Add an aligned linear dimension” in PCB new (KiCAD 7.0.6). I can’t find how to change the arrow style from inner to outer.
How to do it?
Maybe you need to enter a negative value in the “Arrow Length” box
If you checkout the linked GitLab issue you will see . . .
Hildo Guillardi Júnior
Yes. Actual code only does
. . . but yes, good catch.
Huh, negative arrow length…
But it does exactly what I need.
Big thanks !
