How to change Angle on Wire to Bus Entry
I have 8 parallel wires going from side-by-side pins on a chip to an 10 pin male connector.
I want to run a BUS vertically and pickup up some of the horizontal wires.
BUT… they horizontal wires are so close together that I can’t fit a Wire to Bus Entry without the Wire to Bus Entry trying to connect adjacent wires.
Is there anyway to change the angle of the “Wire to Bus Entry” so I can fit it in a tight spot?
Thanks for any help.
I would do it in the following way
Great idea maykol_rey! That should work perfect for me. Thanks again.
So this has nothing to do with the request, but I just noticed that the numbers on the ULN2002 on the left side are the letter ‘I’ and not the number ‘1’ like on the right side. Is this just a bad part? And it’s a bad part in the KiCAD library, I think. Time to dig into the datasheet and maybe open an issue.
The I1-7 and O1-7 are the pin names, not the pin numbers. Obviously meaning input and output as this is a driver IC. So no problem there.
Yup… after I grabbed the datasheet and looked it over it made more sense. I think the font choice is suboptimal, it should be a capital I with the bars at the top/bottom. But I’m happily corrected and educated, so on the whole I’m happy to have learned something new. I appreciate you being nice too. Reason I keep coming back here.
I’m rather sympathetic to eyesight issues at my age: Retiredfeline: Christmas pudding series :wink:
