I think there is a change from 5.0
in 5.1 and 6.0 (master) when a pin is given a net name but is not connected,
this does not translate to PCB pad
When routing BGA breakout, I try to apply a “tighter” rule to the BGA connected nets by using a BGA net class, however the NC pads prevent breakout routing
I can explicitly connect the net by adding a trace and via
However, I would like to avoid doing this.
Besides setting a smaller default clearance, is there a way to assign a net class to these unconnected, but named, nets?
Sample Project unconnected-net-issue.zip (7.6 KB)
