How to add Value fields in schematic symbols
Hi - rookie here running Kicad V9.
Is it possible to add and place several value fields in a schematic symbol ?.
I have created a new symbol (using exisisting symbol as template) in symbol library for a Transformer with multiple secondary windings.
I would like to add a value field next to all Windings to fill in Voltage values for the windings, when placed in the schematic.
Is that possible - and how ?
I apologize if the topic already has been described, please guide me to that topic then.
Thanks in advance.
You can have only one value field per symbol.
But you may add a unlimited number of user fields to any symbol.
Look into the documentation:Schematic Editor | 9.0 | English | Documentation | KiCad
Aditional custom fields can be created with the “symbol properties” dialog (doubleclick on empty space around the symbol)
This suggests that you have added new symbol in KiCad symbol library.
If yes than this is wrong way. You should make your personal libraries for this.
Hi Piotr -
I was not totally clear in my question.
My new symbol was added to my user library - i.e. the symbol library named the same as the project name - in the projects folder.
Its not the default kicad library, which I know is Read-only thus you cannot add new symbols here.
Thanks for thoughts.
Thanks mf_ibfeew -
Thats exactly what I found out by trial and error - my best learning method :wink:
My remaining problem is to safely place fields physically in the symbol, such they appear logically on the component when placed in the schematic.
I have tried messing around with Position X, Position y values in the prperties - in symbol editor.
AND saved it each time I made a correction.
Then I close all files and projects and make a fresh restart to load my schematic again.
When I now place the freshly edited and saved symbol from my user library, the field positions tend to be arbitrary - either they appear as a stack under the symbol reference postion - or they seemingly appear to be positioned increasingly to the left of the symbol.
I can however place the fields to my wish in the schematic and fill in the values.
Oh well - I guess its a question of more messing around and learn how things appear.
Thanks a lot for your suggestions - appreciated !
Most probably you have reached 95% of your destionation and only the “automatic fields placement” is disturbing you.
Try: global preferences–>Schematic Editor–>Editing options–>Symbol Field automatic placement–>disable automatic placement.
You have also the possibility to disable the “automatic placement” for every added field in the symbol editor:
  • doubleclick field to get “Edit xyz field” dialog
  • disable checkbox “Allow automatic placement”
Thats it !
Was just gonne replay with my findings and now I can tell you I reached my destination !
Under field properties I uncheked “Allow automatic placement” for all my fields in question - worked a treat :wink:
Thanks for the journey - learned loads :innocent:
