unfortunately I’m not a big help for you (also beginner), but would you mind telling me how you added the logos/graphics to the silk screen?
mfg
mfg
Normally you should post in another thread, but since you are new too, I will be helpful.
If you press the “O” key, and click on the board. A menu will pop up to select a footprint. If you select the button that says “Select by browser”, you can view all the footprints. There is a library with many different silkscreens that you can choose from. Be warned that importing a netlist with the option to delete extra footprints will remove them.
Only if a recent thread exists with the same topic otherwise a new thread is the way to go.
@Rene_Poschl
Sorry, for confusion, this was a split from another thread.
The link of the original is in the top left under the first post…
I didn’t edit the posts after I did the split. Mea culpa.
