how to add plugin for my kicad windows?
what is the purpose of plugin?
how to generate .brd file in kicad
c:\Users%USERNAME%\AppData\Roaming\kicad\scripting
To extend and enhance the capability of the suite
Using PCBnew either via eeschema to design the circuit and push the netlist or directly
KiCad doesnât use .brd files, it uses .kicad_pcb files.
How to download the script for Windows
If we download the script, that we have to past the file which we downloaded
Please help me with step by step instructions this will be helpful for many users
Is there any way to convert the .kicad_pcb file to .brd file
What .brd file, for what purpose?
There is a viewer for .brd files but there is no viewer for .kicad_pcb file. The purpose is for check the placements and routing without kicad application
The extension .brd is used by different ECAD programs. Even kicad layout files had this extension before 2014.
Anyway the short anser is ânoâ, at least from KiCad.
You can ask in a forum of the other program if they have a kicad_pcb importer.
A baby steps tutorial would be nice. If someone knows how to download a plugin, install it, and execute it, that would be super helpful if they could describe the process.
There is this topic: https://docs.kicad.org/5.1/en/plugins/plugins.html
but I am only on a handshake relationship with Python and C. Well, itâs more than that but we are not dating.
A âhow toâ for the preinstalled plugins would be nice. I see plugins in the plugins folder but I do now know how to work them. There may be a topic that is relevant but I have not yet found it. Thanks in advance.
The link you posted is for internal plugin system that nobody uses as far as I know. Iâm not even sure itâs still maintained, certainly no 3rd party plugins using that system have been published widely.
Plugins that come with kicad preinstalled are footprint generators (wizards). The stuff you get when you do File -> Create footprint... in the fp editor
They are useful and there are some available on the interwebz.
But most often what is referred to as plugin are pcbnew action plugins. Kicad doesnât package any but there are plenty available from various contributors.
You can find fairly detailed instructions of how to install plugins on my pluginâs wiki page. Those instructions are applicable to most plugins, unless author provides alternative instructions which you should follow.
Thank you! Here are some notes about the install. I have not tried to create symlinks to the repository folders.
C:\Users\username\AppData\Roaming\kicad\scripting\plugins Does this mean that the folder is still writable by KiCad and is there a way to test this? Everything seems to work!Windows shouldnât ask you for permissions if you are copying files into your userâs folder (i.e. user are logged in is the same as username in the path).
To test you can try my plugin, if you can save config and it persists between plugin launches than the directory is writable for kicad.
