Hello. I want to reverse (engineer [I guess, Mod]) the board. On to upload a BMP snapshot of the board to the PCB layer?
For example.
It should allow you to now. Welcome to the forum.
This option has been added to KiCad-nightly about half a year ago:
Both the stable KiCad V6 and KiCad-nightly V6.99 can be installed at the same time on the same PC. Once a project has been saved in the newer format, you can however not open it again in the older format. But when KiCad V7 is released (expected end of January 2023) it can open the V6.99 files, as V6.99 is pretty much the test bed for KiCad V7.
PCB Editor / Place / Add Image
For me it looks like:
What KiCad version did you use?
Copy (and paste here) the complete info from: PCB Editor / Help / About KiCad / Copy Version Info
Application: KiCad PCB Editor
Version: 6.0.9-8da3e8f707~117~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.15.0-56-generic x86_64, 64 bit, Little endian, wxGTK, xfce, x11
Date: Nov 24 2022 00:22:58
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.86.0
ngspice: 36
KICAD_USE_OCC=ON
KICAD_SPICE=ON
You need to use a current nightly/testing version (6.99) for that feature. Your screenshot is probably from a standard release version (6.0.x).
I already wrote itβs only in KiCad-nightly:
But itβs easy to read over such details. KiCad version V6 and V6.99 is very difficult to distinguish between from screenshots. Anyway, posting the version info should clarify it quickly.
Application: KiCad PCB Editor (64-bit)
Version: (6.0.9), release build
wxWidgets 3.2.1
libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 10 (build 19044), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Oct 29 2022 23:44:28
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.79.0
OCC: 7.6.0
Curl: 7.83.1-DEV
ngspice: 37
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
That is indeed the regular βstableβ version of KiCad ant it does not have that feature.
KiCad-Nightly can be installed alongside the stable version. KiCad-Nightly is also in feature freeze for some time and it will become the stable version around the end of January 2023. It can be downloaded and installed from the KiCad website.
There is one important gotcha though. Files saved in KiCad V6.99 format can no longer be opened in the stable KiCad V6.
OK. where can I download KiCad V6.99?
If that is not enough, then I may give you another hint tomorrow.
updated to 6.0.9-93. No buttons
Version: (6.0.9-93-gee05b67599), release build
wxWidgets 3.2.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Date: Dec 13 2022 04:10:40
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 37
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I guess that youβre not very familiar with Open Source software and the development of it.
With Open Source software you can often have different versions of the same software installed. There is a βstableβ version (Currently V6.0.9 for KiCad) that is intended to be used for projects, and there is a βdevelopmentβ or βnightlyβ version (Currently V6.99 for KiCad. Nightly versions always end with 99 in their version numbers). The Nighty has all the latest features (such as this bitmap thing) but because the features are being released early in the development process, itβs likely and even expected that the -Nightly version has bugs. The curious people are supposed to live with them, while the engaged people are hunting for such errors and report them back so they can be fixed (This is done on gitlab). The βNightlyβ originates from having a new version built literally overnight so there is a fresh version every morning.
KiCad-Nightly has to be installed as a completely separate program, and it also has itβs own configuration directory.
Thank you. Found 6.99. Everything worked out.
