How ot use a rule area to avoid everything except ground
I’ve creating a board to close an alumunium extrusion.
So my board will be screwed to the aluminium extrusion box, and I want to ground the the box via the screw.
But I don’t want any track other than ground on the bottom layer, because the aluminium can rub on the PCB and the soldermask might not be enough to avoid a short circuit.
My first idea is to create a rule area around the corner of my extrusion box, to avoid putting any track or via or pad. But I still want to have a ground connection.
Is it possible to allow the GND net inside the rule area and create a DRC error for any other ?
Or should I just ignore the DRC violation for the GND.
I think that I would be not using any rule area for this, but:
  • mounting hole with enough big pad (grounded), or
  • mounting hole with user defined pad shape if you don’t accept pads being cut by board edge.
My issue, is not really with the pad.
But I want to avoid to put any track where I’ve draw my arrow.
Right now I’m doing it with a visual check, but it’s easy to do a mistake.
But you have written:
So you need pad.
I don’t have KiCad here to check it, but I suppose you can assign bigger clearance to the pad (I think I have used it defining fiducials). If the pad will be GND than GND will connect to it, but any other net will have to keep specified clearance.
If you can have ground via a zone fill then you can use a keepout zone to keep out tracks but allow zone fills.
Thanks, I didn’t think of it, as It allows to create an unwanted zone. But it is quite unlikely that I’ll mess up with another zone other than GND
