How this
is supposed to work?
for instance, I created this net class…
It should paint those lines blue following the Schematic Setup, right?
Also, the Resolved Netclass at the bottom should show 90_OHMS instead of Default, isn’t it?
How this
spelling mistake.
advice: use the prefilled dropdown in the netclass label instead of writing the netclass manually.
What does it mean? The software gives 2 things, but I should just use one?
the advice should come with a reasoning…
Yeah, that was my first mistake. I thought the schematic would create net classes and populate the “Schematic Setup window” but this does not happen, unfortunately.
Then I had this lowercase 90_omhs form a test of another day, and today I have realize it was using a different case.
But the big question here is that the Toolbar button does not Create Netclasses, it just add the wire there if the Netclass exists
The issue is that we can type the name of the Net class field.
But typing does not create a new one or select one by filtering the closest one in the dropdown list.
