Hello, I’m making some layers for my PCB in Inkscape before bringing them into KiCad,
And from what I understand the convention is to have a small gap of around 0.05 mm as mask opening, so if there is misalignment the pads are not covered in the mask.
But I kind of want to do the reverse, as I have all exposed traces and really don’t want misalignment to result in a gap of exposed FR4 in between the trace and the mask, so thinking having a small overlap will resolve that issue…but how much is a mask going to be off…are we talking in mm?
You can widen the copper track or narrow down the mask graphics on it. See How does solder mask layer work? – the graphics describe the mask opening, so narrower graphic line exposes less copper while wider line may expose the board material, too.
