witawat
January 23, 2025, 11:37am
1
Hi everyone
I have a problem defining the Zone for a circle
I want the copper to be 1mm away from the edge of the circle
Is there a way to draw a circle to handle this problem?
I have tried
File > Board Setup > Design Rules > Constraints > Copper to edge clearance.
The result is not what I want.
Best would probably be to place a mounting hole footprint and set its copper clearance.
dsa-t
January 23, 2025, 11:43am
3
I [also] typically use a mounting hole footprint for this, then set a custom pad clearance.
wxE5
January 23, 2025, 12:39pm
4
If you don’t want to use a custom footprint, you can also group the mounting holes and add a group name:
You then can create a custom DRC rule:
(rule "Clearance to mounting hole"
(condition "A.memberOf('mountinghole')")
(constraint hole_clearance (min 3.5mm))
(constraint edge_clearance (min 3.5mm))
(constraint clearance (min 3.5mm)))
Result:
JamesJ
January 24, 2025, 2:59am
6
The error is telling you exactly what the problem is, and the correct syntax is shown in the first few lines of the syntax help. Add this above the rule:
(version 1)
system
Closed
April 24, 2025, 2:04pm
8
