I want to set 1.5 mm clearance for a net class:
But when I set it into my net, it get’s 0.25mm ckearance:
Is that because it says (diff pair)? I have not routed it as diff pair
Thanks!
Thanks!
Diff pairs are created by ending you net names in N and P. Maybe KiCad sees L-IN as the negative part of a diffpair L_IN and L_IP. What version are you using?
You’re right!
I’m using the latest version, I renamed it to L_INPUT and it stopped doing that.
My (beginner and questionable) opinion is that Kicad should use something else, like _N, -N but not just N. Just in English, there are tons of words ending with N
Thanks @Jonathan_Haas!!
Differential pair net names can end with “+” and “-” too, not only P and N.
That’s why I’m asking which KiCad version you use. I believe diff pair handling has been improved with 6.0.x, so it will display the correct clearance and only use the diff pair clearance if you actually create and use a L_IP net near it. But maybe this exact issue has not been fixed. So your version would be helpful.
Thanks Jonathan!
I’m using 6.0.4:
Application: KiCad (64-bit)
Version: (6.0.4), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Mar 18 2022 03:04:44
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.6.0
Curl: 7.78.0-DEV
ngspice: 36
Compiler: Visual C++ 1928 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
This should only happen if you also have a net called L-IP – do you?
If not, this is a bug that maybe @JeffYoung can take a look at
This looks like False isolation shown in pcbnew (#11314) · Issues · KiCad / KiCad Source Code / kicad · GitLab.
