Hi.
I want to connect Hole 1 with other component.
like picture.
I’d like to know how to connect a part without drawing with another.
Hi.
like picture.
There is a schematic symbol for mounting holes with connections you can add to your schematic, assign the mounting hole footprint and connect it as needed.
Alternatively you can use WireIt plugin to add connection directly in pcbnew. But this way your connection will not be preserved if you do an update from schematic later.
Wireit is not needed here. That tool is only necessary if the project has no nets to begin with. Otherwise just edit the pad properties to enter the already existing net (of course wireit can make it easier)
Also if we suggest the use of a plugin then we might as well link to it https://github.com/xesscorp/WireIt
