Sorry if the title seems a bit vague, I am trying to do a PCB layout for a couple of vacuum valve/tubes. I am trying to double the track thickness by having tracks between pads on both sides of the board. But when ever I try to do this KiCad only ever seems to allow one track between pads. If I lay the track on the Front CU and then go to do another on the Back CU the FCU track will disappear. is there a way to do this, I have done some searching but not found a solution, in the drawing package I have drawn two tracks on the schematic, but that seems to make little difference.
Any answers please keep it so an old git can understand.
Cheers
Adrian
