How can I prioritize my Net classes VCC on top?
In the above picture, I have two different Net classes. I want to prioritize my net class VCC. Is there a way to make it?
The order of net classes in that dialog makes no difference. Nets can belong to only one netclass.
Netlist is the file used to export connections from schematic to PCB. Since V5 it is not needed thanks to “Update PCB with …”.
What you have here are net classes.
So, it there a way to priortize the net classes so that design rule follow that order.
As has already been said . . .
The order makes no difference. Each net only has one netclass applied to it/associated with it . . . regardless of that netclass being at the top or bottom of the list.
So if your net is netclass VCC it won’t be evaluated against the Default netclass . . . select a track on your PCB and take a look at it’s netclass
