My (2 sided) board has a ground plane on much of the bottom layer. I would like to have a small V+ plane (or area) in copper for heat spreading.
I’ve created the ground plane. Then I’ve created a small area and assigned it to V+. However when I look at the 3D, The ground plane covers the area where the V+ plane should be.
I’ve performed ^B then B a number of times with no luck.
If I put a keep out area on the bottom where the V+ would be, I cannot add the V+ plane.
I think what you want is to edit the “Zone Priority Level”.
You can do that by first selecting a zone by clicking on it’s boundary and then hitting the “e” key for edit.
