How can i fix this warning without edit pcb design?
can i ignore this warning and make pcb?
most probably yes, but in the end you are responsible and have to decide.
more information: Upgrading from v6 to v7
The warning tells you that the footprint used on the board is changed compared to the one in the library.
Whether this is a benefit or problem for you, depends on what the change is specifically.
You will have to dig deeper to know whether to ignore it or not.
I just started with V7 (7.0.5) and I experienced a number of these warnings. What I found is if you edit the footprint from the PCB board menu the changes are stored locally and will be different from the library.
So now you have to know if it was changed on purpose or some other problem has cropped up.
I would:
Make a copy of the design.
In the copy up the footprint from the library
See what changes.
