Warning: Footprint ‘SOT-23’ does not match copy in lbrary ‘Package_To_Sot_SMD’
I’m also getting a bunch of Symbol ‘2N7000’ has been modified in library ‘Transistor FET’
This all occured as I transitioned over to KiCad 8.0
You have at least three different options.
The option that suits you best depends on your personal preferences and workflow. I guess these warnings are mostly important for people working with database driven, or otherwise verified libraries, and for them it is an important message. If you are working on a hobby level or per project free-lance then this warning may be more bothersome (and distracting) then it’s worth and disabling may be the best option. Also note that it’s easily reversible if you disable the warning, so you can revisit it at a later time (Maybe put it on a checklist to do before creating and sending out Gerbers).
