How can i do more visible net line?
Hi everybody, i want to learn how can i do more visible net line ? I design pcb and check unconnected line. But i forced when finding line. For example ;
Therefore i want learn easy way for find if there is it.
To find unconnected lines, I usually turn off every layer and rendering for everything except the ratsnest. Then the unconnected lines show up very clearly. Then I can re-enable layers and go back to fix the unconnects.
I think this would be worth filing as a wishlist item on the bugtracker: configuration option for the ratsnest color for improved visibility.
There is an option to change the color, but it doen;t work yet on OpenGL view.
I really like to work with KiCad :slight_smile: But I have poor color vision so I would have the option to change both the ratsnest color and width for improved visibility.
Thank you and wish you a wonderful day :slight_smile:
We don’t want to have old threads revived, so I’ll close this. But as for the wish, KiCad 6 already had and 7 of course still has the ability to change ratsnest colors in the Appearance panel → Nets. You can also change to curved lines in the left hand toolbar which IMO makes them easier to see. For width you can file a wish to the issue database.
