How can I create double traces between pins
Hi. I’m new to KiCad.
I’m trying to create traces on both sides of the board from two pins. I have a rats net from the pin to the other. I can create a trace on one side of the board. But when I try to create the same trace on the other side, the first trace (on opposite side of the board) disappear.
Is there a way to create new rats-net for the other side once I have traced the rat?
Regards
Arvid
in pcbnew… button called ‘disable auto delete old track’ - usually on the left hand side toolbar menu, right underneath the ratsnest control buttons.
Thank you, Joan_Sparky.
So easy… :smile:
As of 5.0.2, which I am currently using, this button is no longer there.
Pcbnew -> Preferences -> General Settings -> Legacy routing options -> Auto delete old tracks
^^Works only in legacy editor :slight_smile:
Either switch to legacy to do the double trace, or I tricked it by placing via mid-track. Not perfect. but works.
Maybe some update could fix this.
