How/Can a verilog ".V" be imported into a schematic?
I have a verilog .v file I need to convert into a schematic showing normal schematic symbols (not block diagrams).
Is this possible in KICAD? If so where can I find the tutorial?
Thank You
KiCad is a PCB layout tool with schematic entry capabilities. It also can be used to drive the ngSpice circuit simulator.
Kicad is not a Verilog simulator and has no capability to interpret the Verilog language.
OK, thank you for the replies.
I trying to see what is going on in this .v file to learn (need visual).
Could any one help with terminology:
what is a verilog schematic called?
what is a verilog schematic viewer called?
Could anyone refer an application to view/convert .V as a graphic
(again logic gates not block diagrams).
Not this image
I would like something that is not an ISE (all the ones I found were 20GB or more, too large.).
Thank You
