I currently work on a layout were I often switch between shove and walk around mode to keep previous routed segments how they are. To do so I have to open the Routing Settings, change to the desired mode there and then need to close the window again. So in cases where I switch after a few wires back and forth it gets quite annoying and I’m wondering why there is no shortcut to switch the routing modes or did I just not saw it?
I’m still working on 5.1 so if it was added for 6.x you can ignore this but if not this may be a good shortcut to add later (if possible).
